Brake upgrade option for GL (W164)
Old 10-05-2015, 06:21 PM
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
We received inquiries regarding to make light weight two piece rotors available similar to what we did for ML63.
Three size of front rotors:
330x32mm (26.5 lbs)
350x32mm (29.5 lbs)
375x32mm (36 lbs) - This is an extremely heavy piece.
I believe most GL are equipped w/350mm or 375mm (late models) and very few 330mm.
However due to the recurring brake issues, MB must provide bigger rotors on GL/ML e.g. for W166 the rotor is 375x36mm (estd 39 lbs), ML63 is 390x36 (36 lbs)
Bigger is usually better but not necessary true unless the rotor metallurgy is improved. In fact we have improved rotor metallurgy so that we can build our two piece rotors with substantial weight saving, yet can outperform OE's bulky and heavy rotors with amazing durability like we did for C63/E63, ML63 and other models.
World's First: RacingBrake 2-Piece Brake Rotors ...
RacingBrake also offers a complete upgrade brake system with RB calipers replacing OE's heavy and bulky floating calipers with the best braking system that your GL deserves.
Here is our reference offer for ML63 AMG
http://www.racingbrake.com/category-s/7280.htm
Similar brake upgrade options are offered by RB for the similar luxurious SUV below:
  • BMW X5/X6
  • Cadillac Escalade
  • Jeep G-C SRT8
  • Ranch Rover
  • Porsche Cayenne
We look forward to serving your brake replacement/upgrade needs.
Old 10-06-2015, 06:08 PM
CLS550
How about the rear?
OE rear rotor is 330x22mm, so with big drum brake the rotor dia is too small to make two piece rotors, so we plan to offer a rear BBK 360x26mm rear two piece like we offer for ML63 with MB rear 4 pot calipers or if you can source rear ML63 OE floating calipers.
The front can be GL's 375mm or 390mm rotors like for ML63. Calipers can be MB's or RB 6 pot calipers.
Old 10-07-2015, 09:46 AM
WaveyKat's Avatar
Something Slow
hmmm it would be sweet to see them on a GL :-)
Old 10-07-2015, 11:41 AM
CLS550
Agree.
Many big wheels upgrade available and done, but you see only factory small brake behind those large wheels which makes the set up (wheel & brake) highly in-proportional and looks "weak".
Racingbrake has BBK to fill up your big wheels* at very affordable prices.
* In development is a "Huge" brake kit for GL/ML with 432mm front and 410mm rear rotors (requires 21" wheels).
Quick Reply: Brake upgrade option for GL (W164)
