Keyless go will not lock/unlock
We have 2012 GL550. The Keyless go feature for the lock/unlock is not working. Will only activate on trunk. However, the smart key/key fob will work with all doors and trunk. Seems like it could be antenna issue, but from some research the antennas would fail on driver front/rear and passenger front/rear not both at the same time. Keyless go will start the vehicle. No display for key not recognized.
It is one of two things. Either your sensors have gone bad or the entire Keyless Go module is going / toast. Does you keyless start still work??
Mine went and I had to replace the module... $1,000
