Error codes and ABS ESP warning help please
Hello;
I'm getting some lights on my dash w ABS ESP warnings
using code reader I'm getting 5 codes
P0845 -Powertrain
Transmission Fluid Pressure Sensor/Switch "B" Circuit
P1425- Powertrain
p061B - powertrain
U140B - Network
U3FFF- Network.
Any help would be great so I can replace some parts or sensor myself.
I will take it in if I cant diy.
P0845 -Powertrain
P1425- Powertrain
p061B - powertrain
U140B - Network
U3FFF- Network.
I think you have found your problem---change the pressure sensor--however before doing that I would get a second opinion from an indy who has a copy of DAS Xentry and who will be able to corroborate the findings!!
My Indy clear all the error codes
replaced Aux battery and repair both rear ABS sensor
Sensor Switch "B" circuit was an stored error not a current error.
I did a transmission service. hope that helps. .
