2009 GL550 airmatic problems
Hi guys. I tried to serch for info on my problem but could not find anything. Maybe you can help me. A few days ago my 2 years old son was playing in the car by pressing all the buttons in the car. The next day when i started the car it was stuck in spot mode and the ride was very firm and uncomfortabile. The height was good and when the height control button was pressed the car would rise and lower as it supposed to. So the pump was working. I checked fuses (32, 53, 107, 108) and all seemed to be fine. I pulled the airmatic control relay (green) and tried to replace it with the yellow from the right corner because it had the same configuration. Something wrong happend and now my engine stalls all the time when i turn on the pump. If i drive it, when it goes above 30mph the pump tries to kick in and the engine stalls again. Please help!
Have you put the relays back EXACTLY where they were before you replaced them? I think you have TWO different problems. Stuck in sport mode and now engine stalling. I'd be the stalling issue is something you did when swapping the relays.
As far as the sport mode goes, just leave it for now. Get the other issue fixed first.
