GL 320 CDi low boost pressure
Hi guys,
Having an issue with a GL 320d going on limp mode. Fault is low boost pressure. Recently I replaced the Turbo because of a high boost pressure issue ...
Did anyone come across this issue ?
Thx,
Thx,
pressure sensor orifice is usually dirty at your mileage. remove sensor and clean up as needed.
check pressure regulator.. linkage gets often stuck.
have the high pressure side pressure tested- your previous overboost might have compromised the intercooler and now it is leaking
Which pressure sensor are you referring to ?
Thx for your time
