285/40/22 or 305/40/22 for 2013 GL450
Old 03-02-2015, 05:27 PM
Powerguy1's Avatar
2007 GL450
Just ordered new summer wheels 22x10 ET 45 for my 2013 GL450 and trying to decide between these two tire sizes. The 285/40 (11.22") is slightly narrower than the stock GL550 21" tire (11.61") and the 305/40 (12.01") is slightly wider. The offset and width of my new wheels are the same as GL550 oem 21's.
Looking for a beefier look without tires sticking out past fender flares. Recommendations appreciated on best tire size, or if there really is a major difference in look between the two, and pictures if you have them.
Attached Thumbnails 285/40/22 or 305/40/22 for 2013 GL450-image.jpg
Old 03-02-2015, 06:52 PM
nynd's Avatar
2018 E63S
Seeing as the 305/40 will have a wider sidewall - I'm inclined to suggest that one. With a 22" rim, a little more protection can sometimes protect the rim - it's minor, but every little bit helps! Also, your speedo error will be approx 3 to 4 mph off... so going 60MPH on speedo will really be travelling at 63 MPH.
Old 03-02-2015, 08:10 PM
Powerguy1's Avatar
2007 GL450
285/40 is .22% slow and 305/40 is 2.2% slow
Old 03-05-2015, 04:23 PM
cyclrder's Avatar
18 E63s Wagon 15 GL63 (sold), 10 Turbo TT MT, A36 Bonanza, 20 JLU Rubicon
295/35/22
have had no issues and no rubbing... Pirelli Zero is the only tire.. and hard to find.
At first I was hesitant about the low profile.. but running 39lbs all the way around and driving on the streets of Brooklyn... haven't blown one out yet!
afr0deezyak (02-26-2021)
Old 03-10-2015, 03:24 PM
Powerguy1's Avatar
2007 GL450
You have the wider wheel arches than my 450. Convernd with the tires looking too wide on my narrow body GL.
Originally Posted by cyclrder
295/35/22
Old 03-20-2015, 09:25 PM
fcs25's Avatar
E350 (gone), W203 C55, X164 GL550
I have run both 305/35 and 305/40 on Pirellis on an HRE 22 * 11s, no rubbing issues.
the 305/40 feels a bit heavier and on hard lock turn, you are very close to inner fender.
hope that helps…
Old 02-26-2021, 09:26 AM
afr0deezyak's Avatar
2013 GL450
You just made me a happy man, I live in Brooklyn too and have a 2013 GL450 I been debating for months if I should buy 22z. Now its a done deal, Im order the 22x10 wheels and put on 285/40-22 tires. Sounds like a solid combo based on your specs.
I will come back and post pix once I get them installed.
295/35/22
Old 02-26-2021, 10:58 AM
cyclrder's Avatar
Hi,
I actually moved to the same sizes that are coming on the current GLS 22 inch wheels... cheers.
Quick Reply: 285/40/22 or 305/40/22 for 2013 GL450
