Replacing rear step chrome plate on bumper
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
Folks -
Anyone replace theirs? Does it require removal of the bumper?
Any help is appreciated. I bought a 2014 CPO, has some scratches on the chrome which are bugging me....
Figured i'd check. Searched to no avail!
Thanks,
Aceman
Thanks,
Aceman
I wpould recommend you source the part 1st - and with thatpart in hand you can verify it's "stick on".
I would not pull the old one without having "new" in hand - once confirmed adhesive - best procedure is to use a heat gun low-setting to soften the old one.
Keep the beat !
Keep the beat !
Thanks Fab,
I sourced it on getmercedesparts dot com, Looks like there are no fasteners but figured i'd check first...will call the dealer tomorrow to confirm and get her ordered up.
Heat and fishing line usually do the trick if its the 3m style tape.
Aceman
Aceman
Thanks - will be doing the same
Is it just heat required to remove the existing piece?
Thanks,
DRP
Dr Pesq -
After looking at the parts diagram on a couple websites - there are clips that i'm seeing. I don't think its as easy as i fabrisd stated. If you google the p/n, you'll see what i'm talking about...
Aceman
Aceman
DRP
