Does anybody know how to modify USB port?
S580, GTC, GL550, NEW S550, S63 (Sold), S550 (Sold), ML350, C230
Hello Guys,
I have found both the Media connector and USB connecters located in the center console useless in charging my iPhone. I have resorted to a dual port cigarette plug with very unsightly cables running from back of console to front seat. This is ridiculous on a $110k car!!! So, I am looking to modify my USB port to allow for higher amperage that should fix this problem. I first instinct is to find a qualified stereo installer but maybe I can handle this with some help from you guys. Has anybody done this???
media cable is a high amp charger.
I have no issue charging my 6 efficiently. Possible yours is not functioning properly?
I don't have the newer cable. I have the old one with an adapter and its similar in trickle charging. But I will definitely get one tomorrow and test.
The USB data port has 500ma charging capability per USB port specs think of it like a PC/data port
Yes - current flagship smartphones are best charged at controlled/regulated 2A+ - that is USB charging port..
Most owners find the right shortie 12v-port/cig-adapter charger to put in the 12V port front - or put it in the rear 12V - and run the charging cable up along the seat to the front...
I tried the MB USB to Lightning cable with little to no success! 1% per 15m. So, I am going to continue to pursue modifying the USB port to 2+ amps.
You don't need to modify the ports, they need to be repaired so they will work as intended.
