GLA Class (X156) Produced 2013-2020
Wheel Specs & Offsets-GLA250
Old 08-18-2014, 03:27 PM
Artichoke50's Avatar
2011 M-B C300 4Matic
I've ordered my GLA250 with the 19" AMG wheels (part of the the Sport Package in Canada). Does anyone know the detailed specs of these wheels? I think they are 19x8, but have not found the WHEEL OFFSET info anywhere.
I need this info to order snow tires to be mounted on 18's...so perhaps someone would at least know the 18 inch wheel specs (rim width and offser)?
While we're at it, do we know whether or not the car comes with run-flats and/or whether or not there is a spare tire option available?
Thanks in advance for your help!! (In case you're wondering, the M-B sales rep and service/parts counter are useless--no surprise!)
Last edited by Artichoke50; 08-18-2014 at 11:58 PM. Reason: Forget one piece of info.
Old 08-20-2014, 11:17 PM
Strafe1's Avatar
2021 E63 S Sedan
The wheels are 19x8.0. The offset is 44.
Old 08-20-2014, 11:20 PM
Strafe1's Avatar
2021 E63 S Sedan
That is for the GLA45 AMG. I don't know if the 250 is the same. The offset on the AMG is 43.5 to be precise. Tires are 235/45 on the 19's.
Old 08-27-2014, 01:19 PM
gjan's Avatar
Mercedes GLA
Wielen voor GLA
Zegt zijn Mijn wielen. 235- / 45 R 19-van 8Jx19ET43.5
Old 09-20-2014, 01:24 PM
JohnnyM57's Avatar
e63 ed1 / 911 GTS Cab
Anyone know the offset of the 20inch wheels on the gla45 amg? I may want to bring the wheels out a bit for stance / any opinions?
Old 10-12-2014, 02:55 PM
Boris_Balkan's Avatar
SLK55 //AMG R171
Tirerack is selling 19x8.5's with up to a +35 offset for the GLA250, so I'd set parameters near that for a stance look. OEM offset is +45 on a 19x8 wheel, so it should be fairly aggressive with slightly wider wheel and +35 offset
Old 10-19-2014, 11:20 PM
cains10's Avatar
The owner's manual says:
GLA250 4matic - 19" - 8.0x19,offset 43.5 mm, tires 235/45x19
Winter 18" - 6.5x18, offset 38mm, tires 215/55x18
7.0x18, offset 46mm, tires 235/50x18
Old 10-19-2014, 11:24 PM
cains10's Avatar
GLA45 AMG - 20" - 8.0x20, offset 43.5mm, tires 235/40x20
Quick Reply: Wheel Specs & Offsets-GLA250
