GLA45, GLA35 AMG (X156, H247) 2014 - present (two generations)
power lul from 3rd to 4th
Old 10-29-2016, 05:39 AM
olmate's Avatar
GLA45
has anyone noticed a big drop in power changing from 3rd to 4th
I gave it a squirt tonight in sport mode when changing from 1st to 2nd the car leaps forward same 2nd to 3rd but when changing 3rd to 4th there seemed to be a big lul in power before the car got going, has anyone else noticed this or is this normal.....
Old 10-29-2016, 10:20 PM
Alexander Hartl's Avatar
subaru STi
are you manually shifting the car or letting the car shift by itself in sport mode?
Old 10-29-2016, 10:24 PM
subaru STi
if you are manually shifting the car then you need to let the car rev to a higher RPM before shifting the car so that you are still in at a high enough RPM when you engage the next the gear. If you "short shift" the car you won't be in a high enough power band to spool the turbo.
Old 10-30-2016, 12:50 AM
olmate's Avatar
GLA45
Im leaving it in sport mode, iv had tooo many missed gear changes in manual....
