GLC43 High Speed or High Rev Stall
So, we just got out car back from the dealer - we were having issues with the car putting itself into park when the Start/Stop would engage - and it became dangerous as cars would expect us to take off at the stop sign or stop light and the car was in park (almost got rear ended) - but it wouldn't let us just put in drive - we would have to turn off the key and then turn on. Apparently it was a battery modulator of some sort that monitored the battery charge...anyways, it seems to be fixed.
But after I picked up the car, I noticed something strange. Not only did it seem underpowered, it also would feel as if it bounced off the rev limiter and pulled power. You know that feeling. But I wasn't in manual mode - I was just getting on it getting on the freeway. So tonight I took it on the highway and you can see where it almost stalls out, and then re-engages...it's only at higher speeds so I can only get it to do it higher up on the revs. Check out the video. Any idea what that may be?
Frankly - your Owner's Manual or a Salesperson with AMG expereince..
1. Let's get directly to your "issue" - you need to know your AMG:
Mercedes-AMG vehicles: the automatic transmission does not shift up automatically
even when the engine limiting speed for the current gear is reached.
When the engine limiting speed is reached, the fuel supply is cut to prevent the engine from overrevving. Always make sure that the engine speed does notreach the red area of the tachometer. There is otherwise a risk of engine damage.
To shift up: pull steering wheel paddle shifter ;.The automatic transmission shifts up to the next gear.
2. You really should note the break-in instructions - sure, everybody gooses their new rig a few times - but since you don't know - how many times have you pushed to fuel cutoff - see breakin below...
"The more you look after the engine when it is new, the more satisfied you will be with its performance in the future.
You should therefore drive at varying vehicle and engine speeds for the first 1000 miles
(1500 km).
Avoid heavy loads, e.g. driving at full throttle, during this period.
Change gear in good time, before the tachometer needle is 2/3rd of the way to the red area of the tachometer.
Do not manually shift to a lower gear to brake the vehicle.
Try to avoid depressing the accelerator pedal beyond the point of resistance (kickdown).
Additional breaking-in notes for Mercedes-AMG vehicles:
Do not drive faster than 85 mph (140 km/h) for the first 1,000 miles (1,500 km).
Only allow the engine to reach a maximum engine speed of 4,500 rpm briefly.
Change gear in good time.
Ideally, for the first 1,000 miles (1,500 km), drive in the Comfort drive program.
After 1000 miles (1500 km), you can increase the engine speed gradually and accelerate the vehicle to full speed.
Keep the beat !
(1500 km).
Keep the beat !
GLC 43, MITSUBISHI PHEV, BMW Z1
Looks to me like a speed limiter - European cars generally have them at 155 mph.
If you were supplied with all-season tyres in the US market, I think I read somewhere that the there was a 130 mph limit due to the speed rating on the tyres.
Also have a look in the menu - there is the ability to add a "winter tyre" speed restriction - maybe it's on inadvertently?
I'm taking it in on Monday. Not sure if it's Gas - the transmission is acting really wonky. It shift points are all over the place, coming from a stop it slams into gear, it think its transmission related.
Just got word from dealer...needs new transmission. So bummed. Also, they haven't even addressed the loss in power.
So I got a brand new GLC43 and drove it back to back with mine and with the technician in the car and he and I felt the massive loss on power. So I'm dealing with a Bad Transmission AND bad turbos or engine or just a Bad Transmission. Either way car is out for the the next few weeks. Sucks. Bad.
Never should have bought new year model for both Engine, Transmission, and Chasis. Future Buyers hold off...we are the test dummies.
I hope it gets worked out to your satisfaction quickly.
right to be forgotten
I don't agree with your conclusion though, the car has been out since 2015, the engine has been around for a long time as well. The transmission is used in nearly every other model. Failures just happen unfortunately, just think about it, if they didn't happen there wouldn't be any garages
Good result Told you to take it in
It is not a new model engine. This engine has been in production for since early 2015 and detuned variants existed before that. Transmission problems would easily explain the loss of power whereas an engine issue does not jibe with the evidence from your video.
Just got word Transmission won't be here till March 18th. This is such a shame. They dropped the Transmission pan and it was full of shaved metal flakes.
They are hoping this is why the power wasn't getting put to the ground, but won't know till they install the new transmission. Sucks.
(1500 km).
Keep the beat !
(1500 km).
Keep the beat !
