glc 250 x253
Just have a local shop remove the factory mufflers and put 2 oval magnaflows on..
A little deeper note..
Note any changes to the exhaust will introduce some drone, and in these its right at 2k rpm ie highway cruising.. a decent amount of dynamat extreme in the truck floor plastic tub base sides will help a fair bit without loosing the tones you are after..
do you have the M274 2.0T engine?
You can get catless or high flow cat downpipes.
There are also a few aftermarket exhausts being sold in China.
C class will not fit. The piping is routed completely different in the back end.
