Mr. JLT's GLK
Old 07-26-2013, 04:05 AM
  #51
bha1980's Avatar
2010 Mercedes Benz GLK220 4Matic BlueEfficiency
Okay I've changed my mind; the black rims look way better. I'm not usually a fan of blacked-out lights but they look great here. I can stare at the side view all day.
Great job.
Can I ask, how much did everything cost from stock to what you have now?
Old 07-26-2013, 02:44 PM
  #52
Mr. JLT's Avatar
To many to list
Maybe 4000$ but I'm a do it my self type of guy and I have a great auto enthusiast network.
Old 09-13-2013, 06:34 PM
  #53
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Still not my cup of tea, but it does look like it was fun to do!
Old 10-29-2013, 10:17 PM
  #54
PiNoY Chedeng's Avatar
GLK350 4MATIC, X5 4.8i, C6 GS, FJ Cruiser 4X4
Ditto..
Old 10-29-2013, 10:20 PM
  #55
Mr. JLT's Avatar
To many to list
its not for everybody but the Mrs loves it.
Old 10-30-2013, 01:57 AM
  #56
TheRealBarryC's Avatar
E63 S211 Estate
...and that is all that matters.
My GF just picked up a black 2012 which I am hoping I can resist modding. My BMW already has more than I should have.
Old 12-23-2013, 04:32 PM
  #57
kilika518's Avatar
2011 GLK
Removing Emblem from Hatch
I love the black on black on your wife's GLK. My project over the year. However my mercedes emblem cracked this weekend and when I went to remove it I saw the center piece in locked in. How did you get this off?
Thank you
Old 12-23-2013, 04:50 PM
  #58
kilika518's Avatar
2011 GLK
how did you remove the grommets for the hatch emblem?
Old 12-29-2013, 09:29 PM
  #59
Mr. JLT's Avatar
To many to list
just pushed them in and took off the plastic cover inside the hatch to remove them. and I got 3 new grommets from the deal. I also have new badges that I didn't use. a new glk 350 and new 4 matic if some one needs them
Old 02-02-2014, 01:59 AM
  #60
toyo1448's Avatar
2010 glk 350
H&R springs
Mr JLT, love your glk!!! I've looked into lowering my glk as well, but they say they don't make springs for 4matic? How did u make yours work? Do you think the strut bar makes a noticeable difference? Here's a pic of my GLK
Old 02-02-2014, 05:21 AM
  #61
N91K's Avatar
GLK350, G55, AMG GTS, C63 507
^^ Very nice GLK you got there!
Old 02-02-2014, 08:19 AM
  #62
Mr. JLT's Avatar
To many to list
Nice GLK, I dig the basket . H&R makes springs for our GLK. Kw also makes some nice coilovers.
Old 07-06-2014, 04:33 AM
  #63
silv3r arrow's Avatar
2011 Mercedes GLK 350 4Matic
weet looking ride,probably the best glk I've seen.
How much did the hre's cost you if you don't mind me asking and how low did you go with the springs, cause I've got 18's for the winter and want to get 22's or 20's and lower it for the wheel gap. My issue is if I lower it and in the winter put the 18's on will it sit lower then the summer setup
Old 07-07-2014, 02:18 PM
  #64
rmfnla's Avatar
Ain't it the truth...
Old 08-18-2014, 12:52 PM
  #65
Mr. JLT's Avatar
To many to list
bumpty bump
Old 08-20-2014, 05:11 PM
  #66
ashwats's Avatar
slk
Can you please share what coatings you have on top of the paint to make it shine like that?
Old 08-21-2014, 10:28 PM
  #67
Mr. JLT's Avatar
To many to list
I buff it with 3m perfect it 3 or 4 times a year. I use eagle one wax or zymol and use eagle one or turtle wax as you dry. And it spends every night in the garage
Old 09-02-2014, 09:27 AM
  #68
Djorge's Avatar
GLK 220 CDI Sport
Amg calipers that fit GLKs
Hey thanks guys. We just wanted to build something a little different. I'll get started pretty soon on the wheels and I need to measure the mounting holes on the front and rear calipers to see if any of the other models share any of the suspension/ braking components such as calipers and rotors as I plan to build some BBKs for the front and rear unless I can get some brembo/Amg calipers to bolt up if not I'll mill some brackets.
Hey there, did you manage finding which AMG calipers are direct bolt ons to the GLK? Dont they have same spindle fittings as the C class ones?
Old 09-02-2014, 09:58 AM
  #69
JDROCKS's Avatar
'11 E350 4MATIC Wagon
Props for the work done, looks awesome btw!
Old 11-22-2014, 09:06 PM
  #70
MaDDog65's Avatar
2013 GLK350
JLT,
Have you had any problems in front with the 265s?
I want to get 265/45x20...don't know if it will rub?
Old 11-23-2014, 09:11 AM
  #71
Mr. JLT's Avatar
To many to list
Originally Posted by MaDDog65
JLT,
The fronts are 255/35/20
If your GLK is lowered I'm not sure if a 265/45/20 would work.
Old 02-21-2015, 11:21 AM
  #72
Smudger's Avatar
GLK350
Mr. JLT
Kudos for an amazing job. I hope you can answer a couple of questions.
The chrome trim on the doors, is that stuck on with adhesive or what? How do you get them off?
Same with the badges etc. at the back. Are they just stuck on? Remover with dental floss??
Again - great job. I envy your skills, I would have buggered it up if I had tried to do half of what you've done.
Cheers, Les
Old 02-21-2015, 11:43 AM
  #73
Mr. JLT's Avatar
To many to list
Originally Posted by Smudger
Mr. JLT
Cheers, Les
Yes the chrome trim had double sided tape on it. I used a heat gun and an eraser wheels to get the glue residue off then buffed it with 3m perfect it. I used a small flat head screw driver to get the chrome strip corner off 1st. then I just used my fingers.
The rest of the chrome around the windows I paint matched
Badges on the back are the same except for the Mercedes emblem it has 3 grommets that it slides into, if you remove the badge just go 3 new grommets from Mercedes cause they break easy so does the emblem.
Old 02-21-2015, 11:45 AM
  #74
Smudger's Avatar
GLK350
Thanks for the speedy response. I also emailed you about the rims but I found the info on these pages.
Les
Old 03-01-2015, 10:29 AM
  #75
Djorge's Avatar
GLK 220 CDI Sport
FYI, yesterday I confirmed the E63 AMG brackets match my GLK front caliper fiting holes, seems only the offset slightly different may require longer bolts with spacers.... Further updates to ve posted soon
Quick Reply: Mr. JLT's GLK
