Worn headlights question
Saw this the other day on the top portion of my headlights...looks as if it's probably sun damage...I just bought a car cover for it since it does spend the majority of the time under the sun...but it gets real hot under the car cover as well...
has anyone had similar damage? If so, does anyone know how to fix it?
I'm going to try to buff it out and see if that helps.
It's too upclose. Looks like it's just scratched up. When I bought mine new, I put xpel headlight clear covers to prevent damage to the lens. After 5 years the headlights look new. Automatic car washers will also ruin your headlights over time (they become foggy on the outside). The good thing is that there are plenty of restoration kits available.
I haven't had a lot of free time this week, ill try to see what happens with a mothers headlight restoration kit I have...if not ill just live with it I guess...its actually not very noticeable unless you know where to look, the rest of the lens is fine and the other headlight is perfect...I think it might be too late to put the clear film over it to prevent further damage.
350 GLK, C280
Agree those look like scratches from either clearing snow with gravel in it or someone with a big belt buckle , snaps or zippers leaning over the glass to service the car.
I would think twice about a cover, especially in hot climates. As you said the heat builds up and with moisture under the cover can 'mottle' the paint. You get spots that look hazy and the cover can actually stick. Unless the cover is well ventilated, it is probably better to just keep a heavy coat of wax or finish protection on the vehicle.
but I do understand the cover situation...sucks, but I have to keep my car outside in the warm and humid and rainy south florida sun...also, theres a big ol' sappy tree the lives next door...any advice? or is wax still enough?
heres some more pics...I used the Mothers headlight restoration kit with the drill attachment...but nothing...made it smoother though...lol
the kit does come with 2 levels of sand paper, which might do the trick...but I always feel a little queazy applying sandpaper to the car....its barely noticeable...but it does show...like clear vintage plastic patina (I think I'm overly romanticizing a scratch don't you agree?)
350 GLK, C280
Wow, those scratches are deep! If you were in the North, and seeing they are on the drivers side, I would have said that a snow plow went by and threw a plow full of gravel, but I don't see it on the paint. It looks as if the plastic cover was removed and set down in gravel. I doubt that the sun would have made those long straight scratches. Was the car parked where kids congregate? The small random pattern looks as if someone was leaning against it in dungarees for quite a while, moving their but while they talked, and then slid off. You can always grind it down more and if worse comes to worse replace the part. However, you notice it but I doubt if anyone else would.
but I agree that if it gets worse, Ill have to replace the lens...I already saw some on ebay for around $150...so its not breaking the bank, but for now those scratches are not worth getting new lenses...
I guess ill just keep the cover on it for now until I have time to do a thorough rubbing, waxing and polishing...
I think I need to invest in a car port...
I've used sandpaper several times to improve clouded plastic headlight lenses. Anything from 1500 to 3000 grit wet or dry paper should work. The courser grits work faster but take more polishing to finish up. Use it wet rinsing every few minutes. The only caution is to masking tape off the edges of the fender and hood next to the lens. It's too easy to sand the paint accidentally.
