Front bumper removal
GLK CDI 320 2009
Hello ,
I received my DRL for my 09 GLK and i need to remove the bumper to install the LED .
I need some help or a tutorial to know where iam going before doing it , all the hidden bolt/screw ,i did the rear bumper for hitch install and it was easy , the front look bit more complicated to remove toh .
thanks for any advice here !
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Removal of the fender liner is straight forward. I bought the special tool to remove the press pins which hold the liner in place but they can be removed without it. The nuts are plastic which you will have to remove also. Remember to lubricate the studs before reinstalling the nuts to prevent them from locking with rust if you are in a salty road area.
