LED back up lights
Old 10-05-2014, 05:23 PM
vinnieg's Avatar
2013 MB GLK 350
LED back up lights
I am planning to put LED back up bulbs in my 2013 GLK 350. Anyone know how to get to them? Step by Step pictures?I am a little afraid to just start taking things apart.
Old 10-26-2014, 08:07 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Hit up XenonDepot for the reverse LEDs...they are super bright white.
Easy DIY job...remove plastic panel to access rear tail light assembly...remove taillight housing...swap out bulbs to LEDs...test LEDs/polarity before re-installing the housing...if they light, then go ahead and re-install....done.
Old 11-14-2014, 09:07 AM
HK_WIL's Avatar
GLK250 Bluetec 4Matic
Any blown bulb or any notification of this type after switching to LED?
Old 11-19-2014, 04:03 PM
Marek_Norway's Avatar
2009 GLK 220 cdi
I would try that philips xtreme LED T16 921, but it is not possible to buy theese in Europe and xenondepot wants $77 for shipping to Europe Any no-error alternative to Philips? I really need stronger backup lights, GLK stocks are sooooo weak...
Old 01-24-2018, 02:48 PM
rmeier1's Avatar
GLK 250
I just replaced the 921 bulbs with Sylvania LED type. They are much brighter but because they use much less current, .25A vs 1.5A each, you will get
a "check reversing lights" message. Pressing the OK button on the steering wheel is a small price to pay for the extra visibility.
Anybody know what the other missing bulb behind the inner clear light bezel is. Looks like a standard bayonet bulb and If still connected it would
defeat the error message, (and add even more light),
Old 01-24-2018, 04:11 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
You could also get canbus enabled LEDs and not get that error message.
Old 01-27-2018, 01:22 AM
Flipbound18's Avatar
2015 Mercedes Glk350
Inline resistor
Old 01-27-2018, 10:08 AM
rmeier1's Avatar
GLK 250
Yeah a 12-15 ohm resistor in parallel would do it. It would be better connect wires the original bulbs & place them in
the empty adjacent reflector I mentioned. Cheaper too. Hmm... where did I put my soldering iron?
Quick Reply: LED back up lights
