Lug bolt spec for factory 17" wheel
Fiat 500
Hi there, I got a set of used 17" factory wheels (the one in the middle) and not sure if I needed shorter lug bolts. Car is currently running 20". Thanks
http://www.benzworld.org/forums/atta...-wheels-10.jpg
2011 W463.237; 1991 W461.401
The OEM wheel bolts (14x1.5x45mm R14) that are currently holding the 20" wheels on your GLK will be a perfect fit for the 17x7.5 Mercedes 5-spoke wheels. I run the same 17" wheels on my 2015 GLK 350.
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Read some where they may require longer bolts than what is standard. There are longer bolts if you have a spare tyre in the tool kit to try.
Fiat 500
Thanks guys!!! Wheels changed, using the same bolts from the 20". I have to say the 17" provides a much better ride and for me, "confidence" as well (without worrying too much about potholes)!!!
Out of curiosity, where did you get the wheels? That's what I wanted to run, but couldn't find a source for them here in the states (could get a UK company to ship them, for quite the price!). Ended up with some 17" C-class wheels instead.
Would love to see pics if you have any
Thanks for the pic -- I like the look. Are you in Canada then?
Just to share, pics of the C-class rims on my GLK are in this post:
https://mbworld.org/forums/glk-class...ml#post6007530
GLk definitely runs quieter with smoother ride. Performance / steering minimally affected.
The bolts are different on the 17 inch than the 20 inch (my OEM).
Fiat 500
