60K MILEAGE SERVICE. ROYAL PURPLE ?
GLK 2010 @ 90K MILEAGE. COAST TO COAST.
ROYAL PURPLE PRODUCTS ?
@60K MILEAGE SERVICE
THE FIVE FLUIDS.
- ENGINE OIL CHANGE.
- TRANSMISSION FLUID FLUSH.
- COOLANT FLUSH.
- BRAKE FLUID FLUSH.
- POWER STEERING FLUID TOPPED OFF.
I'll be selecting my own products to use on my benz on this service, I read a lot of good things about Royal Purple and decides to use most of their products for my fluids. The following products is what I'll be using on my benz until I find something better I suppose. Any comments about them ?
- Royal Purple 05540 SAE 5W-40 RP Series Oil - 5 Gallon Pail
- Royal Purple MAX ATF Synthetic Transmission Fluid Oil 12 Qt. 01320
- Mann Filter (CUK 29 005) Carbon Activated Cabin Air Filter
- Royal Purple 01326 Max EZ High Performance Synthetic Power Steering Fluid - 12 oz.
- Mann-Filter HU 718/5 X Metal-Free Oil Filter
- TYC 800129C2 Mercedes Benz Replacement Cabin Air Filter
- OES Genuine Coolant/Antifreeze 1 Gallon
- Royal Purple 01600 Purple Ice Super-Coolant Radiator Additive - 12 oz.
- Pentosin (BF-DOT4-1000ML) Brake Fluid - 1 Liter x 2
- Red Line (60103) Complete SI-1 Fuel System Cleaner - 15 Ounce
- Rain - X Latitude WIPERs
- Wagner ThermoQuiet MX1341A Semi-Metallic Disc Pad Set, Rear
- Wagner ThermoQuiet MX1406 Semi-Metallic Disc Pad Set, Front
- Hengst Fleece Oil Filter Kit
THE FIVE FLUIDS.
- COOLANT FLUSH.
2020 C8, 2020 defender 110X, 2019 720S, 2014 GLK 350 4matic, 2015 escalade platinum, 2013 RRS HSELux
@60K MILEAGE SERVICE THE FIVE FLUIDS. - ENGINE OIL CHANGE. - TRANSMISSION FLUID FLUSH. - COOLANT FLUSH. - BRAKE FLUID FLUSH. - POWER STEERING FLUID TOPPED OFF. I'll be selecting my own products to use on my benz on this service, I read a lot of good things about Royal Purple and decides to use most of their products for my fluids. The following products is what I'll be using on my benz until I find something better I suppose. Any comments about them ? - Royal Purple 05540 SAE 5W-40 RP Series Oil - 5 Gallon Pail - Royal Purple MAX ATF Synthetic Transmission Fluid Oil 12 Qt. 01320 - Mann Filter (CUK 29 005) Carbon Activated Cabin Air Filter - Royal Purple 01326 Max EZ High Performance Synthetic Power Steering Fluid - 12 oz. - Mann-Filter HU 718/5 X Metal-Free Oil Filter - TYC 800129C2 Mercedes Benz Replacement Cabin Air Filter - OES Genuine Coolant/Antifreeze 1 Gallon - Royal Purple 01600 Purple Ice Super-Coolant Radiator Additive - 12 oz. - Pentosin (BF-DOT4-1000ML) Brake Fluid - 1 Liter x 2 - Red Line (60103) Complete SI-1 Fuel System Cleaner - 15 Ounce - Rain - X Latitude WIPERs - Wagner ThermoQuiet MX1341A Semi-Metallic Disc Pad Set, Rear - Wagner ThermoQuiet MX1406 Semi-Metallic Disc Pad Set, Front - Hengst Fleece Oil Filter Kit
ROYAL PURPLE.
i started looking into royal purple after this article.
http://www.animegame.com/cars/Oil%20Tests.pdf i started looking into royal purple after this article.
The royal purple tested was a heavier weight vs 0w weight of the competition. We know that wear does happen during start up in cold mornings. With variable valve timing, direct injection and Autostop you want oil to flow freely and immediately and not thick in cold engine start ups. What's the pour point of the oil at 0 degree centigrade or farenheight? I use blackstone labs to determine if there is enough TBN after an oil change to mean that the engine was protected throughout the oil's lifespan. I have been a supermod in the Evom since 2003 and all engine breakdowns of the 4G63 turbo was due to royal purple.
http://www.benzworld.org/forums/w203...le-others.html
2016 Golf R, 2014 GLK
Royal Purple is extremely overrated and over priced. There are plenty of other alternatives that perform as well or better.
Liqui Moly is what we've been using in our GLK.
That's EVO though, I have read good responses from Benz owners that uses royal purple, guess what Mobil 1 and Mercedes have a deal with each other so Mercedes is required to promote their product. http://www.benzworld.org/forums/w203...le-others.html
i heard of Liqui Moly but wasn't too sure about it, i will research it right now.
To me it proves very little. It's only shows one property of the oil. Oils that did well in this one test, might be completely unusable after after a few k miles in the engine and ruin the engine. Not saying that they are bad oils, just saying that I would not make my oil decision based only on this article.
I ran oil lab analysis after 40k and 4 oil changes at the dealer (I did 5th oil change myself). The only comment was slightly higher iron content due to 10k miles on the oil. I'm putting much fewer miles this year, so will be interesting to compare the result at 5k miles. Dealer use M1 5w40, I put in 0w40.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
You have read good things about Royal Purple? Where? On their own web site or from reviews written by the the pyramid-scheme MLM distrubutors?
Stay away from Royal Purple. I have written essays on oils in the C63 thread and I am not going to repeat it here, but the bottom line is - stick with MB APPROVED products from reputable comanies that actually know a thing or two about engine lubrication.
THE FIVE FLUIDS.
- COOLANT FLUSH.
THE FIVE FLUIDS.
- COOLANT FLUSH.
Even their Bosch equivalent is not as good.
Stay away from additives/cleaners
I would go with OEM recommended oils for both tranny and engine.
Brake fluid doesn't really matter as long as it's DOT-4 and you flush it every couple of years.
EDIT:why would you top it off with a different fluid? Chances are it doesn't need to be toped off in first place. \
Keep in mind that MB comes with coolant additives that dissolves slowly (there is supposed to be a cartridge in the system) and hence 15 year service life. Not sure if you need or want to add more additives.
Okay, maybe I agree with you after all :-) - and if it needs to be "topped off" then there's a leak...
Greetings guys,
i talked to my mechanic and yeah i guess i wont be using royal purple fluids instead of the OEM one. im only gonna be using royal purple 5w40.
stay tuned to my progress
@ https://mbworld.org/forums/glk-class...e-project.html
