Changing Transmission Fluid
Old 03-30-2015, 03:28 AM
b12ucehuy's Avatar
GLK350
Question Changing Transmission Fluid
2010 GLK 350
I bought an Service Kit to change my ATF fluid.
9 qt Automatic Transmission Fluid 134
Torque Converter Drain Plug And Sealing Washer.
Transmission Oil Pan Drain Plug Sealing Washer.
Automatic Transmission Fluid Filter.
Automatic Transmission Pan Gasket.
I checked the engine bay today and is there NO fill tube for the Transmission Fluid, I search the entire engine bay...
Lucky I checked before draining the fluid. Do i need to pump the new fluid via the drain plug?
Old 03-30-2015, 01:32 PM
Marek_Norway's Avatar
2009 GLK 220 cdi
This is definitelly not DIY job! What I know, workshops do this with special tool - pump, they pump the fluid under pressure from the bottom of the car (probably through the drain plug)...
ningster's Avatar
2013 GL350
I believe most cars require filling through the dipstick hole...
this is what you'll need...
Old 04-11-2015, 11:03 PM
Wodeshed's Avatar
Current: 2007 E350 P1 and P2
Lots of us do this job ourselves. I did it several times on my CLK and am now about to do it again on my E class.
There's a special tool available to refill via the drain plug:
Mercedes ATF Refill Adapter Mercedes 722.9, 12 x 1.5 Thread
Link: http://tinyurl.com/m76wzts
Don't thank me...I got it from somebody else in the forums.
Quick Reply: Changing Transmission Fluid
