brake issues 2010 glk
2015 GLK 250 o3 clk 430 09 c 300
I have 40,000 miles and the brake pedal slowly goes down when the pedal is held on for a long time on a hill or such. The pedal also seems soft after driving a distance.. The brakes were bleed at the dealer 20,000 miles ago.It stops fine. The dealer stated that they have never changed a master cylinder.??? Other than this issue the car is flawless
I have 65K on mine and it also stops fine I don't have the problem you are stating unless I tried to stand on the brake pedal while standing still. Brake assist only comes into play in a panic stop.
My mechanic says I still have about another 10K left on my pads. I'm not necessarily a slow driver but I have found what helps me with the brakes is manually down shifting as I am coming to a stop. I do it almost all the time. I let the trans do some of the stopping work.
I've done it a few times as well and still do it on long downhills. But I found just keeping in S produces similar amount of engine braking where I often barely touch the brakes.
