MY NEW PROJEKT! GLK 350 Build!
Did a TEST of the Comand Online 4.7 so all worked Before I started the facelift retrofit of the interior...
Just had to do this retrofit. A W207 AC panel instead of the old looking original. Just plug n play. I will do a custom made panel for it.
Almost done....
That interior looks fcking good...you said you have contacts for mb parts, I am looking for genuine dab module for comand ntg4, I am in Norway, maybe you can ask for this? From 2017, there won't be fm in norway anymore and I don't want cheap dab fm transmitter...
#32
Thank you, I tried to find part number for this, but I don't have WIS or any other part database, checked also on german forums, ebay etc but no luck...
#34
JohnnyC (03-17-2017)
#36
#37
Normally it is one LED in the end of a fiber optic but I Always add a led strip since I Think the OEM is to weak.
#39
#42
Steering Wheel:
W218,W212 or W166 FL steering column
Any steerngwheel you like. W205,W218,W176,W217 and so on
Button A09990507009107
Button A09990506009107
Contac plate A0994640417 or A0994641000 (or A1664640417 for a rebuild of old plate.)
#43
Interior console:
ALL FL consols fit ALL GLK models. One just sold on ebay for $300
Same with WOOD. Fits all FL consoles.
Glovebox is not changed. Same on preFL and FL.
Cluster frame:A2046803908
Comand screen frame: A2046800334
#44
Comand Online 4.7:
Unlocked Comand unit with screen and cable. (I can help here)
Map code for your VIN is $150 euro inc maps. (I can help here)
Pin 14 in conector needs Power with 5amp fuse.
Then all works fine.
#45
Cluster:
Any W204,GLK, W212 or W207 can be used.
Needs programming.
To display the odo it has to be factory new. It can also be done with a used one but then needs to be virginized. (I can help here)
Needs programming.
#46
Taillights:
OEM only. Are no aftermarkets made.
Needs repining. (I can help here)
Programming. (I can help here)
#50
Awesome build!
Was wondering if you could answer a few questions.
I have a 2011 GLK 350 and want to swap out the taillights for the new style (2013+). You mentioned that you had to do a few tweaks to get them to function correctly. Other than that, would I simply remove the old lights and replace them with the new? No modifications to the car or lights?
Also, that center console you picked up for 100$. How did you snag such a deal? I'm looking at replacing mine and want to put in the new style. Will any 2013+ GLK console fit?
