MY NEW PROJEKT! GLK 350 Build!
#51
What you have to do is to move some of the pins in the conector. And that depends on wich lights you had Before. LED or non LED. Same with the programing. Depends on what you had Before. I will make a pic of wich color goes where in the conector so it is easier to do. I will also do a print screen of the settings in Star Diagnose that makes it work flawlessly with no error messages.
All the center consoles from X204 and W204 fits your car.
#53
And I already answered that..!! ??
Depending on wich version of taillights you had from factory there are som different pins to be moved and some programming.
#55
OK. Then you have to test each lamp and see witch cable goes to wich lamp. Then just test the new lamp and move the cables to the right place. Then test it for errors and program it until errors disapear and all lights up like it should.
#56
Everyone needs a IWC watch right..?
Bought the clock from a SL65 R231 and the cover from a R172 and started to cut it out.
Bracket cut out and the new hole for it starting to take shape.
Bracket finetrimmed and I added a chromelist for that final luxury touch and then test fitted it by holding it in place. The I did the new hole for the lightsensor that I had to move and did the final mounting and glued it in place.
Look of the rear and then Finnihed and installed. Conected to 12 volt,groung and canbus.
Some nightshoots before it was finnished in place.
I think this is the first GLK with a analouge watch in the world. :P
#57
Received 3,353 Likes
2012 CLS63
nice dash wart
#65
Only looks that way. Dont think you have the actual led. Just the plastic tube and no conector. I conected mine to the glovebox light wich is on all the time when car is on.
#66
Got the bumper and all attachment parts inc grill with 360 camera.
And rear complete....
#69
Old. Old Sport. Facelift color. Bought a old sport cluster just to get hold of the the cover with depth in the trim.
Moving the new trim with depth to the faclift color cluster..
Done.
Installed..
#71
Back from paint. Now I only need to add all parts to them...AND ITS ALOT!
Ready to go on...
ALOT of parts in rear to attach.
Some detail pics of the facelift Xenon aftermarket headlights..
Identical to OEMs..LOVE them!
#75
www.wplamps.com "Win Power" I think. About 700 on ebay.
