MY NEW PROJEKT! GLK 350 Build!
Old 02-24-2016, 11:56 PM
  #76
willi6's Avatar
glk 350 -1981 280ce
rear lights
Originally Posted by Chris The Swede
Taillights:
OEM only. Are no aftermarkets made.
Needs repining. (I can help here)
Programming. (I can help here)
Hi I would like any information about installing rear lights like that that looks really good
Old 02-25-2016, 02:39 AM
  #77
Chris The Swede's Avatar
W222 S63L, ML/GLE350
As it says. Needs to move pins and then programming depending on wich tail lights you have originaly.
Divinefinesse (04-03-2024)
Old 02-25-2016, 04:51 AM
  #78
Marek_Norway's Avatar
2009 GLK 220 cdi
Hey Chris, is it possible to reprogram DRLs from low beams to standard fogs? Btw very nice build, like the luxorious interior.
Old 02-25-2016, 05:18 AM
  #79
Dont understand? You want to remove the DRLs and replace them with fogs??
Old 02-25-2016, 10:34 AM
  #80
2009 GLK 220 cdi
no, no...I have first model of glk with standard fogs (no led strips) and daytime running lights are low beams what in my case are bixenons...I would like to reprogram drl's from bixenons to fog lights...
Old 02-25-2016, 11:57 AM
  #81
All you need is the DRL package. It includes modules for this to work without programing. If you want OEM you must program and yes it can be done of course.
Old 02-25-2016, 12:23 PM
  #82
2009 GLK 220 cdi
I don't want led strips, I only want fogs as daylights, now I have low beams as daylights...
Old 02-25-2016, 12:45 PM
  #83
toobrokeforC63's Avatar
GLA45 AMG 2016
If I could have like 10% of your skills when it comes to cars, I would be a happy men. Your GLK look awesome. I really like the seats.
Old 02-25-2016, 01:49 PM
  #84
ok..Never haerd of that option so that I dont know...Since when you program it for that it is for LED. And that means you will get error messages for broken light and I also dont think it will send enought power to them.
  #85
Thanx a million.
Old 02-25-2016, 02:11 PM
  #86
2009 GLK 220 cdi
Thank you anyway, I have already seen mercedes c class year about 2008, 2009 (what is actually the same like glk I think) which was leaving tunnel and it's lights turned from low beams to fogs, but I am not sure if the driver switched it manually or if it was automatical, becouse you can turn the switch to position only for fogs, but I'd like to have it automatic...fe. when I drive into the tunnel fogs switch to low beams, when I left tunnel low beams switch to fogs again...with switch in position A...this normally works if you turn off drl in instrument cluster, but here in Norway, you have to use lights during all day (drl or low beams) and you can use fogs for drl...I have to ask mercedes dealer...
Old 03-04-2016, 09:55 AM
  #87
WaveyKat's Avatar
Something Slow
very Nice work Question how much a 2010 Covert to 2013+ will cost Roughly?
Old 03-04-2016, 05:02 PM
  #88
Almost impossble to say when the prices on the parts is up to the used markets prices. And for you the US market. I got it cheap here but dont know the avarage prices in US. I can ship alot to you but the biggest things cost so much to ship like dashboard and bumpers.
Old 04-11-2016, 04:01 AM
  #89
Took a phoneshoot of the now finnished interior. All facelift door panels in place. Added a few aluminium parts ad well to make it a bit more excusive looking wich I think looks OEM and not tacky..Like the buttons for the seats and speaker frames... AMG color cluster is not in here though. On the way back to me after service done on it. I will add sport pedals as well soon.
All new bumpers and headlights are also in place. Need to take som good pic of it though.
Old 04-13-2016, 09:33 PM
  #90
dn1127's Avatar
2010 GLK 350 4matic
Hello Chris ,
I had 2010 GLK 350 4matic and can you show me how to convert to the LED tail light and program pin .
Thanks.
Old 04-14-2016, 03:13 AM
  #91
That is easy but different depending on what version you had before. Just take out the old one and put 12v to pins one by one and do the same on the new and you see the difference and where to move pins. And when programming just try different settings on bulb or led options till it works.
dn1127 (04-14-2016)
Old 04-20-2016, 10:21 PM
  #92
Scrambler850XP's Avatar
2010 GLK 350
First off I want to say great job! That is amazing! I have the 2010 GLK with nav & Harmon Cardon sound system. I would love to upgrade my dash to what you did along with the command. Will I still retain the Nav function and the sound System if I swap out the head unit? Thanks a million!
Old 04-21-2016, 05:34 AM
  #93
Of course! ??
Old 04-26-2016, 01:24 PM
  #94
Goin on a Florida vacation now so if I dont answer quickly, thats the reason...Back on May the 12th.
Old 04-26-2016, 02:02 PM
  #95
tazzz3.2's Avatar
glk 350 cdi
wonderful!!!!
congratulation
Old 05-21-2016, 01:11 PM
  #96
croe33's Avatar
GLK 350
Great build! Awesome dedication and patience to do it right.
I just picked up a 2012 GLK. It has the MB Tex seats. I was wondering if you knew what seats from other models will fit the mounts and how much if any wiring would need to be changed.
Old 05-22-2016, 03:59 AM
  #97
Thanx a million..
No clue on that affraid...Front seems easy but rear I dont think you will find any seats that fitt than GLKs own.
Old 05-22-2016, 01:04 PM
  #98
Sam.P's Avatar
'06 E55 / '10 GLK 350 4M
Hey Chris,
Very impressive work. I have an identical 2010 GLK and am drooling by looking at your pictures and prices you're paying!!!
Might be a lot to ask, specially coming from a complete stranger, but I'd be SO much grateful if you could look up the price on a facelifted center console with the knob. I can't find anything under 300$, and they're not even the right color... Let me know if it could be a realistic solution.
Thanks so much for sharing your "projekt" with us, it's absolutely mind blowing
Old 05-23-2016, 05:58 AM
  #99
Where are you located?
Old 05-23-2016, 06:10 AM
  #100
Took some pics..Not the best quality but hey...
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: MY NEW PROJEKT! GLK 350 Build!
