Seatbelt Issues 2010 GLK 350
Old 06-20-2016, 07:27 AM
Bomab's Avatar
2002 ML 320, 2010 ML 350, 2010 GLK 350
Replaced drivers side (female) seat belt receiver. Disconnected the electronic harness connectors. Removed front drivers seat. R/R seat belt receiver. Installed drivers seat and made up connectors. How do I reset the Front Left SRS Alarm notification on the display?
Old 06-20-2016, 04:07 PM
eyeckr's Avatar
2010 GLK350
I had the same sort of issue when I disconnected my seat to replace the seat cover. Now in hindsight I know that I didn't have to remove the whole seat to do it but I caused a SRS light to come up on the display.
I had to buy a ICARSOFT I980 in order for me to clear code. I hooked it up and had the dash SRS light off in about 45 seconds. The best price I found was $129.00 on eBay from TDC-POWERBOXES seller. I think if you go to the dealer it will cost you about the same or more to get them to shut it off. I may consider loaning mine out if you are local.
Old 06-25-2016, 10:36 PM
Bomab's Avatar
Thanks eyeckr, glad someone else had the same issue and found a solution. On with amazon now. Thanks again
Quick Reply: Seatbelt Issues 2010 GLK 350
