Adjusting the rpm
Old 06-26-2016, 09:27 PM
monarc98's Avatar
04 c240 avantgarde,2011 glk 300
Adjusting the rpm
Hi all is there a DIY to adjust the rpm? I think I need to raise it by 1000. Thanks
Old 06-26-2016, 11:26 PM
travelingj's Avatar
2013 GLK250
Just give the skinny pedal a little push ( =
Old 06-26-2016, 11:45 PM
monarc98's Avatar
Thats what i do but Need it really to be permanent to remove the slight rough idling it would be fine if I don't see the headlights shaking when stuck in traffic
Old 06-27-2016, 11:02 AM
bop11's Avatar
350 GLK, C280
It would help if you said what engine you had. Idle is normally set by computer using the idle air servo. If you shake enough to see headlights move, you probably have a vacuum leak somewhere.
Old 06-27-2016, 11:26 AM
monarc98's Avatar
I have the 2011 glk 300. Actually I see it shaking on and off. It's just annoying have to see it in the garage or when full stop and the only thing I could think of is increasing g the rpm. I just changed the plugs and run diagnostics in the shop but no fault found that was just almost 50 days ago.
Old 06-28-2016, 09:28 AM
bop11's Avatar
350 GLK, C280
Probably the air volume sensor needs to be cleaned, the temperature sensor is going bad or the exhaust oxygen sensor is on its last legs.
Quick Reply: Adjusting the rpm
