COMAND screen blank on GLK250 2013
Old 07-18-2016, 08:35 PM
DrRx's Avatar
2011 E350 4MATIC & 2014 GLK250 BlueTEC
Turned on the car this afternoon and the COMAND screen is blank. No radio, nav, back up camera, hands free. Nothing turns on. Tried pulling some of the related fuses and re-inserting but still nothing.
Any suggestions?
Old 07-19-2016, 11:03 AM
lyonkster's Avatar
2011 GLK350
Any suggestions?
Do you by chance have any warning lights on, like the one for battery?
Old 07-19-2016, 02:09 PM
bop11's Avatar
350 GLK, C280
Did the radio work just not the screen? If so, you need to reboot the system. You have to turn off everything remove the key and get out of the car and close the door. Go away for 15 minutes so the system totally powers down. Then come back and try again. Sometimes the screen does not boot up correctly. Don't be tempted to try early. The system does a warm boot when you open the door if it has not totally powered down. The system can store about 10 minutes of power internally even if the battery is disconnected so you need to wait for a period of time to insure it has lost all residual power. Mine will do this once or twice a year.
Old 08-12-2016, 12:36 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
same thing happen to my wife this morning, driving to drop off the kid and the screen was blank but every thing still works. walked him to class and got back in the car and it started right up and everything is normal. I really hate German electrical gremlins.
Old 08-14-2016, 10:26 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
My 2010 has done this when I have a SD card plugged in that it sometimes disagrees with. I suspect the newer GLK doesn't have an SD card in the dash the same way but try unplugging anything you have plugged in as another music source - USB, iPhone, MP3, etc and see if that helps. In my case the Comand screen is blank and the radio plays but no screen and no changing of source or station. It's an occasional pain. I unplug everything, turn off the car and then turn it back on - no waiting. I can plug everything back in then.
Old 08-17-2016, 11:45 AM
LesF's Avatar
2014 glk 250BT (RIP, 3/1/17}, 2010 C300
Then you would really love the old English company Lucas.
Old 08-17-2016, 12:06 PM
AzCamel's Avatar
I had a Land Rover, good time with the Christmas tree lighting up the dash monthly
Old 08-19-2016, 04:39 PM
davidjohnbamber's Avatar
2013 E550 Sedan
You mean: Lucas Electric "The Prince of Darkness"
As a Jaguar owner I was once was working for showed me his incinerated interior of his XKE. His comment was that Lucas Electric had a 3rd headlight setting after OFF & ON, Flicker!
Old 08-19-2016, 08:53 PM
AzCamel's Avatar
wow. thats crazy
Old 08-19-2016, 11:09 PM
LesF's Avatar
Sounds like my old TR-6.
Old 06-01-2021, 04:52 PM
GLKfunbun's Avatar
GLK 250
Hello all,
Today I experienced the same thing out of nowhere (2014 GLK 250). The screen went blank with only the time displayed on the top left corner. Couldn't really find a solution other than a possible issue with the fuses. What worked for me however was holding the on/off button (the round volume button) for about 10 seconds. It first started the radio and then the screen came off completely. I had not washed the car and no extra moisture anywhere I could think of. Before trying this, I tried turning off the car with an hour of leaving idle, started the car but with no luck. Hope this helps someone with the same issue.
Old 06-02-2021, 01:39 PM
andreigbs's Avatar
GLK 250
Typically when the COMAND system is off, the screen will be dark with only the current time shown.
Maybe you (or someone else) pressed the power button last time you were in the car? Or your battery is getting really low?
Quick Reply: COMAND screen blank on GLK250 2013
