Dual USB retrofit
Old 09-14-2016, 11:31 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
Dual USB retrofit
Did the retrofit since mine was broken, did all the usual steps of checking fuses and wiring and determined that mine was broken. I placed a call to the dealer and they wanted $80 for the part, Amazon had it for $60, but at the end of the day I hated the adapter sticking out and wanted a cleaner OEM look for something more useful since the wife does not smoke. I bought the dual USB port from Amazon for $10. 99 with prime and it took approximately 10 minutes to install, I used the factory wiring plug from the old cigarette lighter for the install.
So if anyone has a broken from 12v then this is an alternative for you, the install rating is beginner/novice level so everyone should be able to do this.
https://www.amazon.com/gp/aw/d/B00R5...40_FMwebp_QL65
Attached Thumbnails Dual USB retrofit-20160914_201059.jpg   Dual USB retrofit-20160914_201752.jpg   Dual USB retrofit-20160914_201116.jpg   Dual USB retrofit-20160914_201810.jpg   Dual USB retrofit-20160914_201818.jpg
Old 09-14-2016, 11:55 PM
LiftOff's Avatar
Magic Toaster Oven
Nice, looks good.
Glad you got a 3 AMP one and not the cheap trickle charging 1.5 Amps.
Old 09-15-2016, 12:20 AM
AzCamel's Avatar
Originally Posted by LiftOff
Nice, looks good.
Thanks, and yes I wanted something to charge quickly and for bigger stuff then my phone like the tablets
Old 09-15-2016, 12:29 PM
glennhl's Avatar
2011 C63
Once again, excellent job!
Old 09-15-2016, 12:59 PM
AzCamel's Avatar
Thank you. I didn't tap into a different power supply after testing it out, seems it didn't supply enough power for the 5v, so u tapped the rear consol power outlet which is the red/green stripes power line, brown is still the ground. Charges much faster now.
Old 09-19-2016, 08:25 PM
guMBy's Avatar
GLK350
Was it hard to take the console apart? I am worried I will snap something. Where are the pry points?
Old 09-19-2016, 09:31 PM
AzCamel's Avatar
takes me less then a minute since i have done it so much on many different MBs, they are all pretty much the same.
There are some tutorial on youtube
Old 09-19-2016, 11:51 PM
guMBy's Avatar
GLK350
I watched a youtube video on how to take the console apart. It went well after using a fair amount of force. I removed the lighter socket, and swapped in the dual USB outlet. I also wired in the little bulb module with the plastic optic that supplied light to the ash tray/change tray. I just hot glued it to the new USB outlet in the same place as it was on the lighter socket thus retaining a light in the ashtray.
Thanks for the USB/Lighter replacement idea!
Old 09-20-2016, 11:26 AM
AzCamel's Avatar
No worries. Check to make sure it's giving you enough power, I ended up tapping into the power supply of the rear (red/green) since it give me a stronger power supply
Old 10-01-2016, 03:10 PM
Mark1000rr's Avatar
2012 GlK
How did you remove the cigarette lighter socket from the ashtray unit? Did you have a special tool?
Old 10-03-2016, 09:41 AM
guMBy's Avatar
GLK350
There were a couple of tabs on the lighter socket that had to be compressed to get it out of the tray. They were tough, but since I was not using the socket anymore I just used some force.
Old 10-03-2016, 02:38 PM
AzCamel's Avatar
I just broke mine apart since I was throwing it out anyways, but there are tabs to compress if you are replacing it with another factory unit.
Quick Reply: Dual USB retrofit
