Multiple misfire.
Old 01-15-2017, 11:02 AM
djc225's Avatar
glk 350
Multiple misfire.
Getting codes po300 along with 302 and 305. Replaced coil on cylinder 2. Seems strange that multiple coils are going bad at the same time.
Before I go replacing the coil on cylinder 5 what other parts might cause a multiple cylinder misfire?
Old 01-16-2017, 12:25 PM
Mmr1's Avatar
2013 glk 350
Bad plug wires, corroded connections from excessive moisture, bad spark plugs can all cause misfire.
Old 01-16-2017, 12:31 PM
Mmr1's Avatar
2013 glk 350
If you want to verify its the coil do an ohm test, I'm sure on u tube you will find out how to do it and what reading is good or bad. You might find several are bad or weak.
Quick Reply: Multiple misfire.
