Mercedes Logo Projector
‘23 Rivian R1S, ‘22 Maybach S, ‘24 Range Rover Autobiography, ‘22 Tesla X, &
Does anyone know how to shut off the logo projector that projects on ground from the rear view mirror? Thanks
Kejad (03-25-2021)
The following 5 users liked this post by BACnMercedes:
ajgk (06-06-2016),
George Gerard (09-16-2018),
JoeMa (05-31-2016),
Neurobit (07-20-2017),
relmerator (11-23-2018)
Actually - in center/COMAND screen - go to Vehicle Settings - and turn off "Locator Lighting" which will turn off the projector lamps.
Alternatively - using your headlight dash control - turning from Auto to Off before exiting the car will also turn off the Locator/projectors - but means you need to manually turn that headlight switch back to Auto when restarting the car.
Keep the beat !
Keep the beat !
Keep the beat !
Keep the beat !
Piece of electrical tape? That's weird MB doesn't let you turn it off..there must be a way.
I can turn it off in my GLE using the Locator Lights menu but I'm in Canada. Perhaps the dealer will know?
Ali.Alkhamis (07-19-2016)
Make sure the Locator Lighting is set to on, while the engine is running, then turn your light switch from the Auto position .... to the right. It seems that the Logo comes on when the engine is running, the light switch is set to Auto, and the Locator Lighting is set to on. When you change the Light switch from Auto, and turn to the right, then turn the engine off,.. the Logo is turned off. This worked for me when I tried it...
Thats the understatement of the year. I'd go with gauche.
Despite that I have not disabled it since I do appreciate the illumination it provides. BTW You mean the side mirrors? I have never noticed one insude the cabin.
Kejad (03-25-2021)
As I suspected its the puddle light. The OEM is less gaudy than the one shown there (its only a star) but still, a badge w&$re item that Id rather not have as standard equipment. My wife simply hates it too (its her car). I've considered the tape solution, but I like the illumination.
I think you can go into the menu under convenience options, you can turn off the lights. But it may also not turn on your headlights when you unlock your doors. Please let me know if I'm wrong.
Door puddle lights with logo projector
Does anyone know where I can purchase the MB door light (at bottom) logo projector light to replace current light for a 2017 S550 Cabriolet?
Thank you kindly.
Thank you kindly.
Might work? They usually respond relatively quickly, mine come in Monday.
