Rear "D pillar" panel clearcoat
Old 05-18-2005, 06:22 PM
v8plus4's Avatar
2019 E63s AMG Sedan, 2021 Range Rover Autobiography "50", 2023 Bentley GTC Speed
The clearcoat on the black rear panels on my 2001 ML320 Sport have begun to crack and peel. Any suggestions on a good replacement source, other than the dealer?
Thanks,
John
Old 05-18-2005, 09:08 PM
N1PRJ's Avatar
2001 ML 430
Rear pilar external clearcoat
I have exactly the same problem. During the severe winter we had, scraping the ice off the back appears to have damaged this clear coat. It is flaking off now in the affected area.
I was thinking of taking it in to have that fixed with some of the chips I got last winter on the front hood. Body shop? My dealer farms this type of work out anyway.
Old 05-18-2005, 09:53 PM
ML God's Avatar
I replace them all the time at work...they are held on by urethane
Old 05-18-2005, 10:06 PM
v8plus4's Avatar
I didn't even think about re-painting them, but with the rates body shops are charging these days, I would think it would be less expensive to just replace them.
Old 05-18-2005, 11:19 PM
mbbodytech's Avatar
04 C320 Coupe MT
There's nothing to replacing them. Like was mentioned, they are just glued on, easy to cut off, easy to put the new ones on.
The best bet for you is probably to have a dealer do it, less hassle.
Old 05-19-2005, 07:36 PM
N1PRJ's Avatar
2001 ML 430
Rear D pillar clearcoat
ML GOD – Oh Great exalted one - I bow to your superior experience – I cower in your presence - How much do these things cost to have replaced?
Would a body shop where I see many MBs be better ($$) than the dealership (much further away)?
Old 05-20-2005, 12:35 AM
ML God's Avatar
The D Pillars are not that expensive...I think they are $60 each. with 1/2 labor each...Where they get you is the damn urtheane The kit is $120 it must be magic urthane...Any Glass company can do the job...they use that stuff
Old 05-21-2005, 06:01 PM
JLLG's Avatar
1997 E320 2000 ML430
What is "magic urthane"? I need to replace one of mine due to it cracking. I thought the part came with double sided tape already attached. Also, I think the part is more like $80.
Old 05-22-2005, 12:16 PM
mbbodytech's Avatar
04 C320 Coupe MT
[QUOTE=ML God]
For my money, the MB adhesive is important for glass, but not for installing these simple covers. Any urethane will work, just make sure they use something that will stick to plastic, otherwise it may fall off!
Old 05-22-2005, 12:24 PM
ML God's Avatar
[QUOTE=mbbodytech]
Yep your correct...but when we replace them at work that is all we have so thats what we charge...any urethane will work
Old 05-23-2005, 08:52 PM
N1PRJ's Avatar
2001 ML 430
Clear coat pealing
I tried to take a picture of what is happening. If the picture comes through - is it just a matter of applying a new coat of urethane? Or does the whole thing need to be replaced.
Also, I not that the top of the panel is lose on both sides of the car. It appears tight at the base, but you can pull the top away from the car a few cm.
Attached Thumbnails Rear "D pillar" panel clearcoat-ml-clear-coat-shedding-sm-.jpg
Old 05-24-2005, 09:54 AM
mbbodytech's Avatar
04 C320 Coupe MT
You need to take that whole cover off and throw it in the trash! The urethane we are talking about is the adhesive used to hold the cover on - the new one.
Old 05-24-2005, 01:28 PM
00ML430 Bulldog's Avatar
2000 ML430
Use a heat gun or a hair dryer to soften the old glue before you pry the old cover off. Makes things alot easier.
Old 05-24-2005, 04:22 PM
N1PRJ's Avatar
2001 ML 430
D pilar pealing
What do you mean urethane? I can pull the top of these plastic pieces away from the car. What it looks like underneath is double-stick foam tape. They both are still tight at the bottom, but I would think the highway wind along the car would be pulling both of these things away from the car at the top, they are so easy to move up there.
Still, even $60 is a grunt-load for a piece of stupid, glossy plastic; never mind a premium for some special glue (that doesn't seem to hold past 3-4 years).
Old 06-01-2005, 06:01 PM
glljr's Avatar
Part Numbers for "D" Pillars
Does anyone know the part numbers for the left and right "D" pillars. The dealer wants $300/each to replace them.
I don't know how "magic" the adhesive at the dealer is, one of mine fell off a year after the dealer replaced it after it cracked. (They refused to replace it for free.)
Thanks in advance.
Old 06-01-2005, 06:44 PM
ML God's Avatar
163-690-06-87 Right side
163-690-05-87 left side
168-670-00-93 ureathane
Old 06-02-2005, 09:56 AM
JLLG's Avatar
Can someone explain how to use the urethane on these panels when they already come with two face foam tape?
glljr, I am thinking that improper surface prep may be the cause why yours fell off
Old 06-02-2005, 10:26 AM
ML God's Avatar
They do not come with foam tape! all you are seeing is a foam seal..no tape
Old 06-02-2005, 10:40 AM
mbbodytech's Avatar
04 C320 Coupe MT
Don't forget to tell him about the special gun!
Old 06-02-2005, 11:33 AM
JLLG's Avatar
Why don't you enlighten us on the "special gun".
Old 06-02-2005, 02:31 PM
ML God's Avatar
Thats why the urthane is so expensive becasue it is designed to fit in the MBZ urethane gun. Dealer cost on the gun is $1600
Old 08-23-2005, 07:49 PM
dcm0505's Avatar
2002 ML 320
Question Urethane gun??
So, do I need to invest in a urethane gun? Have any of those questioning this now made this repair themselves? I've got the same problem, and the peeling is really starting to get just plain ugly!
Thanks!
-Daniel
Old 12-13-2009, 06:28 AM
OttoBon100's Avatar
'11 C300
"D" pillar came off - again!
I have had the right side reaffixed twice by the dealer. Once under warranty because it was peeling and again three years later for free because they "fixed" it the first time and it flew off on the freeway and disappeared. Got back from a short trip this morning and the left side pillar was barely hanging on! Anyone used a special adhesive and done this themselves? Name of the adhesive? I know if I take it to the dealer they will want a couple hundred dollars to fix it since they haven't touched this side.
Old 12-14-2009, 02:13 AM
wampa's Avatar
E500 & ML500
On a previous car, when the side moldings would fall off I used "3M double sided interior & exterior tape". Which can be found at most locations such as office supply stores (staples) to autoshops (autozone) for about $10 -$15. Make sure you stick it on correctly the first time, because once its attached it will be pretty tough to remove. But the most important thing to do is prep/clean the area well, before you attach the tape. What I would is use a degreaser on the area to remove the buildup. Then rinse the area off. Then next clean area off with Isopropyl Alcohol, and let it dry. Make sure you clean both the d-pillar piece, and the area on the car before attaching the tape. This is optional, but you can also heat up the tape with a hair dryer/heat gun. Heating up the tape should allow for better adhesion.
Here is a pic for reference
Hope that helps
Old 12-16-2009, 09:39 PM
OttoBon100's Avatar
'11 C300
Thanks Wampa! Worth a shot.
Quick Reply: Rear "D pillar" panel clearcoat
