timing chain replacement
Old 08-23-2005, 05:55 PM
98ML's Avatar
Hey guys, I was wondering if anyone knows what the recommended interval is for changing the timing chain for an ML320. Also, does it make sense to do the waterpump/timing chain at the same time on this motor? I know with some other cars, once one is being done, it would be very very easy and cheap to have the other done. Thanks for your help.
Old 08-23-2005, 06:38 PM
ML God's Avatar
There is no recommended interval for changing a timing chain. These motors have been out since modle year 98 and I have yet to see one break. It isnt like the Japanease vehicles that have a timing belt
Old 08-23-2005, 06:56 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely due when the engine is overhauled or rebuilt.
Old 11-22-2013, 07:51 PM
Ajay250496's Avatar
Mercedes Benz ML 320
Hey I was wondering if any of you has the Timing belt Diagram for the ML 320?
Old 11-23-2013, 02:22 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There is no timing belt, it is a chain and believe me you do not want to do it.
Old 11-24-2013, 06:37 PM
Ajay250496's Avatar
Yes thats what i meant lol and iits not me its a friend who is a mechanic and he is having problems with this. So i am looking for a diagram of the chain placement if possible. Please let me know where i can get this or post it if you have it available.
Old 11-25-2013, 08:36 AM
Here are the instructions. Special holding tools are required.
Whenever they say "crank the engine" they are not referring to cranking the engine by using the key. They mean so by turning the crankshaft bolt manually.
If this is not done properly and you go to start your engine, all the valves and cam gears will be destroyed.
File Type: pdf
Old 11-25-2013, 09:14 AM
Ajay250496's Avatar
Thank you i will try this and let you know how it goes. Wish me luck
Old 11-25-2013, 09:23 AM
You don't say why you want to change the timing chain but you must know what you are doing with this, because your engine is at risk.
I can't wish you luck because I don't think you have the know-how to do it, very few do.
Old 11-26-2013, 06:33 PM
Ajay250496's Avatar
The person that is doing this is a very skilled mechanic and i am sure he can get it done he informed me today that all he wanted was a diagram so that he can see the indicators .
Quick Reply: timing chain replacement
