Hello everyone newbie here......I have an 02 ml320 with a problem.....
Old 01-25-2023, 10:56 AM
kris805marie's Avatar
02 mbz ml320
About a month ago my instrument cluster stopped lighting up at night. None of the gauges(gas,temp,and tach)are working. And the HVAC just blows and I cannot control those dials either. Car runs and drives fine. All the other controls such as windows work, and when I use my blinkers those do light up on the instrument panel. I have tested all of the fuses in the right kick panel and under the hood all fuses are good . I love this car had it for 5years almost this is the ONLY issue that has arisen. All I've ever had to do is keep the fluids up to par and now this...any suggestions or advice would be immensely appreciated ! Thank you,all!
Old 01-25-2023, 07:10 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W163 forum...
Old 01-27-2023, 01:23 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Check the fuses as per the PDF when the ignition is on or off.
File Type: pdf
Quick Reply: Hello everyone newbie here......I have an 02 ml320 with a problem.....
