Removal of ml320 dash
Old 06-14-2009, 04:24 AM
persianex's Avatar
98 ml320
Thumbs up Removal of ml320 dash
My A/C is blowing hot air. I had it checked and it seems the blendoor or a lever is out. I would like to know if anyone can help me figure out how to take the dash out so I can get to the root of the problem.
Thanks in advance
Old 06-14-2009, 03:13 PM
persianex's Avatar
98 ml320
got it!
I know how to now. I guess whoever have this problem can ask me.
Old 06-14-2009, 10:37 PM
jefferino's Avatar
2000 ML55 (parted out), 92 1jz SC300, 92 Sentra (DD), 05 Cadillac SRX
Just saw this...I could have told you, its fairly easy as I am sure you saw. Just a lot of screws and need to take time.
Old 06-15-2009, 10:34 AM
persianex's Avatar
98 ml320
thank you for helping
Hey man,
Thanks for the support. My problem was that I had no idea where I was looking for screws. I read about other mercedes cars and did different thing, but finally figured it out. For people out there that are going to fix their blend door motor in their ml320, there are screws on top vent and piler needs to come off.
Old 06-15-2009, 08:01 PM
miguel446's Avatar
99 ml320
Tell me more about how to correct this? My AC system has been completely replaced, but I still get temperate (not hot) air when I idle.. I wonder if it's related to this somehow.
Old 06-23-2009, 12:48 AM
Marshall_K's Avatar
02 ML320 Sport, 04 350z,06 E350 4matic
If you have the answer post a link
or copy paste
Old 09-23-2009, 01:01 AM
z.man's Avatar
ml320
Thumbs down ML 320 AC problem
Originally Posted by persianex
Hey man,
so, you never told me how do you take the blend door motor out? do you access it from the golve box?
Old 09-23-2009, 01:02 AM
z.man's Avatar
ml320
how, i need to know please as i have the same problem
Old 10-17-2009, 04:19 PM
beammeup's Avatar
Mercedes ML320
Wink Blender is Stuck in Hot Position
I had this problem on my 98 ML320. Removed 8 screws from glove box and gently removed glove box. Reached in above and to the left of glove box with right hand and pushed on lever on top of blender until it freed up. Turned on the engine and guess what, the blender works now. Do not be tempted to remove the air bag unless you want to involve the dealer in the repair.
Old 10-17-2009, 05:08 PM
LeviDenim's Avatar
2005 E500 4matic, 99 ML 430, 90 E300
Credit goes to Detane for this video DIY. I saved me a day.
http://www.youtube.com/watch?v=XAjCIs1d7q8
Old 06-07-2010, 03:44 PM
sambmer's Avatar
ml320
Need your help
I have the same problem and I need your help with the removal of the dash. I started to try D-tanes, but I don't want to run the risk of having to replace the clips on the passenger airbag.
Can you post pics on location of screws for the dash. I want to remove it but I can't find screws. Any help will definitely be appreciated.
Old 11-15-2010, 07:16 AM
towney's Avatar
ML 320
Can some one give instructions on how to remove dash? I get to the point where I'm stuck at pulling off the center front of dash from radio cluster area.
Old 11-16-2010, 06:56 PM
Stiggs's Avatar
2003 CLK55
Is there a way to do this without removing the airbag? I would hate to mess something up. Dealership quoted me $1200 to replace the blend air flap motor! Might be worth doing it myself.
Old 06-14-2011, 11:29 AM
s4play's Avatar
01 S2000, E46 M3, 99 ML320
Wow, this is the same problem I have on my trusty 99 ML320.
We took the car to get a freon recharge and the A/C blows cold for 3 days before it goes back to hot air. The shop did a leakage test under the hood and said they found no issues using a dye so the problem must be inside the dash somewhere!
Do I need to remove my center console before taking the dash off? My mechanic said I can save some labor if I remove the dash myself but I have no clue where to start.
Is the main area I want to get to behind the radio or more on the passenger side behind the airbag?
thanks!
Old 06-17-2011, 07:04 PM
Stiggs's Avatar
2003 CLK55
The blend air flap motor is located behind the radio/HVAC knobs.
Old 11-13-2011, 04:10 PM
kwtsang's Avatar
ML320
Hi Persianex,
Please provide instruction on replacement of blend motor without removing passenger air bag door. The door is held down to the dash with an 90-degree metal bracket (angle iron). Pulling the door open will break the clips and will change the angle of the bracket and will be hard to put the door back on without leaving a large gap. Even the dealer couldn't find the clips for the air bag door let alone putting the door back on. I know the location of the blend motor, but just couldn't get to it without popping the door open. Please help.
Old 11-13-2011, 04:15 PM
kwtsang's Avatar
ML320
Please provide instruction on how. My 1999 ML320 blend motor is clicking too, and cannot get hot air. Thanks.
Old 11-18-2014, 11:53 AM
aygent008's Avatar
1999 ML 320
Can you elaborate a little more on where the blend door is located. I am freezing my butt off. Thank you sir.
Old 11-19-2014, 02:10 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You first must determine if the Blend Door Motor is at fault or the AC Controller/Amplifier (N19) is at fault.
Do do so, remove the Instrument Panel covers under the driver's side and passenger side. Look in the opening between the end of the console and the Heater Box and you will see a small black box the size of a pack of cigarettes.
Remove the one screw holding it and extend it out to either side and with the engine running, conduct the one test with a DVOM on wires 8 & 9. Pos. probe of DVOM on 8 and neg. probe on 9. Start with the dial turned to heat range and slowly turn to the cold range.
If the voltage changes correctly, then you must purchase a new Blend Door Motor. If there is no voltage change you must purchase a new N19.
Post back with results.
Attached Thumbnails Removal of ml320 dash-2014-11-19_020910.jpg   Removal of ml320 dash-2014-11-19_020829.jpg   Removal of ml320 dash-2014-11-19_021531.jpg   Removal of ml320 dash-2014-11-19_021310.jpg   Removal of ml320 dash-2014-11-19_021212.jpg
Matelot18 (12-24-2022)
Old 12-20-2014, 09:59 PM
ML320VIC's Avatar
2000 ML320
So my understanding is I unplug the N19 module and test the plug by probing it there, or do I keep it plugged in?
Old 06-01-2015, 11:47 AM
leofinsa's Avatar
ml350
hi somebody knows ml350 w166 dashboard removal
hi somebody knows how to removed speedometer on mb ml350 w166 2013...has 2 screws onthe bottom but something on top is stuck ???????need specail tool???
Old 06-02-2015, 05:03 AM
You are on the wrong forum.
https://mbworld.org/forums/new-m-class-w166-149/
Quick Reply: Removal of ml320 dash
