Power Window switch 2001 ML430 fuse and relay location
Old 12-22-2009, 11:02 PM
Racerx18691's Avatar
Mercedes ML430
does anyone know where the location of the fuse AND relay for master console window switch is located? I replaced new window master switch console last nitght and STILL having the same problem. Owner's manual does not tell where the relay and fuses are located for power windows. PLEASE HELP!!!!
Old 01-02-2016, 10:21 PM
Chris Mcclaskey's Avatar
ml430
Here ya go
I looked for an hour with no answers to this question. So for posterity I have posted this on the most common link to appear when I search for Power window fuse location for ML430 or ML320. The location is in the engine bay on the right side in the large fuse box located behind the air filter / box.
Old 01-03-2016, 03:13 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
And what is the problem you are having?
Old 01-16-2016, 11:05 AM
mfgulla1's Avatar
2001 clk430
2000 ML320 100k miles, I recently replaced the window master switch and it didn't help. Today I changed the motor and it worked fine a few cycles, I replaced the panel and now it works very erratically with the new switch. All other windows work fine. Any suggestions? Relay?
Old 01-17-2016, 03:10 AM
To get the proper help and information, you must tell us what the problem you are having.
Quick Reply: Power Window switch 2001 ML430 fuse and relay location
