Bi xenon Retrofit !!!!
Old 04-22-2003, 05:35 PM
spitzeklasse's Avatar
W220 S500
Hy guys I was wondering if any of you had any Information about retrofitting 2003 Bi xenon headlights to 2001 ML . I went to my dealer today and ask them about it and they told me it's gonna take a lot of work . My questions is , Is it plug and play ? and do I need additional brackects to hold the headlights ? Any Info will be very much appreciated !!!
Old 04-22-2003, 05:49 PM
BillM's Avatar
1999 ML430
If you have the adapters it is complete plug and play and takes around 20 minutes or less for both lights. The bi-xenon fit the same as the ones you now have. The only thing you will not have is the washer system and the self leveling. If you do not have the adapters you will have to mess with the wiring pinouts to get them to work. You can order the adapters from Performance Products @1-800-243-1220 x7611, Richard. Tell him you need the bi-xenon ones as they also have the ones for the halogen lamps. Hope this helps.
Old 04-22-2003, 08:42 PM
W220 S500
Thumbs up Thanks!!!!
OK then , I'm gonna give them a call and ask for the adapters . do you know how much the adapters would normally cost ? And say if I bought the adapters will the self leveling works ? lastly do i need to bring my car to the dealer and Have them reprogram using the star diagnosis system .
Old 04-22-2003, 09:50 PM
BillM's Avatar
1999 ML430
Question for you.......
Where did you get your Bi-xenons from? Last I heard they were selling the adapters for $40. Since you are in San Marino you could opt to pick them up since they are located in Van Nuys. No, even with the adapters the auto-leveling will not work. With the 2001 model you will not need the dealer to activate them. After I installed mine I did have the dealer properly adjust them. Cost me $66.
Old 04-24-2003, 04:42 AM
W220 S500
Rusnak dealer
I got mine from rusnak dealer and cost me $ 1200 each.
Thanks for the Info
Old 04-24-2003, 11:21 AM
BillM's Avatar
1999 ML430
WOW, $1200 each.......
I paid $1100 for the set including the adapters. If you need any assistance let me know.
Old 04-24-2003, 07:33 PM
W220 S500
Need adapter!!!
I need the addapter !!! and How do you work the leveler ? because you told me even with adapter the leveler wont work.
Old 04-24-2003, 09:51 PM
BillM's Avatar
1999 ML430
As far as I know......
you can not get the levelor to work. Requires another wiring harness and other parts. Did you call Performance about the adapters?
Quick Reply: Bi xenon Retrofit !!!!
