location camshaft sensor
ml55
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
What was the problem you were having?
How did you know it was the Camshaft Position Sensor and not the Crankshaft Position Sensor?
The reason I ask is that there have been very few reported problems with the Cam Position Sensor but many problems with the Crank Position Sensor.
Mike
Mike
ml55
Mike
Mike
The idler pulley also broke.
Replace the parts,It's cranks an that it!
"I don't know", but i did replaced the crankshaft sensor like 2yrs ago!
ml55
update
I just plug in a OBD scanner
it gave me 2 faults:
1-camshaft sensor
2-EGR valve
Okay where's the EGR valve location?
I hope it's only a gasket, that part is pretty pricely....
1-camshaft sensor
2-EGR valve
The location of B6/1 is on right side of the eng.. You must replace the Oring upon removal.
