Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > M-Class (W163)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-11-2011, 01:52 PM   #1
Another bad FM reception thread
After a recent service on my ML350 I re-entered my radio pin and found I had poor FM reception. Could be coincidence but I am unsure. All that I did to the car was change a relay for the fans under the hood.
CD works fine but FM can not find stations when scanning and if I pick a station volume is very low. I understand it could be the Antenna or maybe an amplifier? Logic suggests antenna to me. So my questions are....
What should I do to trouble shoot?
Where is the antenna located?
Is it in the rear bumber (I have bumper cracks and a hole) or the rear window?
Miss my radio as I use the FM with a bluetooth transmitter for hands free (And Pandora from the iphone)
If it is a big hot mess to fix is their an aftermarket that will fit in and offer bluetooth or at least an aux port? with Nav of course as I have it now...
Thanks for any help you can porovide
Kevin
To remove this ad, register today or login if you already are registered!
KevinL is offline   Reply With Quote
Old 11-12-2011, 08:08 AM   #2
From time to time the radio comes back up to full volume for a second or two... Like a short.....
Old 11-14-2011, 10:06 AM   #3
How many miles, I say either amplifier of a short in the antenna wire where is goes from the car to the hatch.
__________________
2006 S600 - Rocket Couch
1997 Nissan 240sx - Turbo toy.
BryanW203 is offline   Reply With Quote
Old 11-30-2011, 10:19 AM   #4
Thanks Bryan,
Cd and Nav have full sound. Is there a diagram of where the antenna wire runs available?
Kevin
Old 12-01-2011, 03:31 PM   #5
Drives: 2002 ML 320
Quote:
Originally Posted by KevinL View Post
Thanks Bryan,
Kevin
Tha AM/FM antenna is in the tailgate, but your problem is probably a partially broken coax cable in the upper right corner or the tailgate.
Maj. Dundee is offline   Reply With Quote
Old 12-02-2011, 02:45 PM   #6
Thanks for the info. I will post a pic of my tailgate, looks a little different unless your posted picture does not show a cover wrap on the wires. What should I look for?
Old 12-02-2011, 10:24 PM   #7
Drives: 2002 ML 320
You will have to remove the wire loom to reveal the coax cable. Look at the point where the cable takes a bend. If it isn't obvious, you will have to manipulate the cable while the radio is on to check for returning reception.
Tags
163, 2001, 320ml, 350, audio, fixed, fm, low, mb, mcs, ml, ml430, problem, radio, reception, shooting, trouble, volume
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
