Sign in using an external account
| M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2003 ML500
starting issue/wont start
#2 |
Drives: S500 & ML320
starter?
__________________
![]() 1985 500sec, Blew up 1999 ML320, Sold 1999 ML430, Sold 2001 S55, Gone, Came to my house & robbed me at gun point for it 2000 S430, Sold 2001 ML320, Factory NAV & Factory Bluetooth :) 2002 S500, With the fancy key & Linguatronic |
#3 |
Drives: 2003 ML500
I don't believe it's the starter. It continues to try and start until it stops. It doesn't want to kick over. The fuel pump does work when you get under it and listen you can hear it. I checked the shredder valve and gas flow freely so its not a clogged fuel filter. So I'm stumped any Ideas????
#4 |
Drives: 2002 ML 320
Explain the problem a little better. Does the truck not start sometimes........does it happen when it's hot..........was it an ongoing problem and got worse..........etc.
#5 |
Drives: 2003 ML500
I noticed that it was starting to take few sec. longer to start. seemed a little worse when its colder out. I went to leave on morning and it just kept trying to start till it stopped on its own. I can hear the fuel pump kick on, and the shredder valve has a steady flow of gas so I don't believe its a fuel problems. and the battery is fully charged. I'm puzzeled. have any ideas?
#6 |
Drives: 2002 ML 320
Does this happen every time you try and start it or is it weather dependent?
Pushing the Schrader valve really doesn't prove anything. An actual reading with a fuel pressure gauge will tell. When you have this problem, as it is cranking, look at the tachometer needle and see if it moves up slightly. Do this a number of times. If it moves then your ignition circuit is good and it is a fuel issue. If it doesn't then you might need a Crank Position Sensor. Do you have a scanner? You can't own one of these trucks without one. Last edited by Maj. Dundee; 02-12-2012 at 11:31 AM. |
| Tags |
| 1999, 270, 320, 500, battery, car, cdi, change, charged, completely, key, ml, ml500, start, starter, turn, wont |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
