Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > M-Class (W163)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-19-2012, 12:51 PM   #1
Drives: Mercedes CLK
transfer case and clutch pack
what happens when the clutch packs get worn inside the transfer case?
in this case RWD only?
To remove this ad, register today or login if you already are registered!
bluebottle is offline   Reply With Quote
Old 02-20-2012, 10:57 AM   #2
Drives: 2002 ML 320
You are on the wrong forum if you are referring to a CLK.
Maj. Dundee is offline   Reply With Quote
Old 02-20-2012, 12:45 PM   #3
alphonsohall's Avatar
Drives: ML270CDI
In the case of the ML 4x4 design, i would expect that you would lose drive completely (the same as if the rear or front propshaft was removed) as the transfer case has no lock-up facility and acts as a two speed differential to all four wheels. The wheel 'lock' facility comes via the electronic 'ets' system where individual wheels are locked by the calipers as and when a spinning wheel is detected
alphonsohall is offline   Reply With Quote
Tags
1998, 230, 270, bad, case, cdi, clk, clutch, clutches, location, ml, pack, speed, transfer, w163
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
