ML350 2003 rear shocks replace.
Old 05-27-2012, 03:03 PM
stickyfingers's Avatar
ml350 2003
Any tips or pics on my rear shock replacement would be appreciated.
Old 05-28-2012, 03:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The rear struts are replaced as one unit, spring and strut. Some just replace the strut alone but the strut must be remove and then taken to a shop where it can be separated with a special spring compressor.
File Type: pdf
Old 05-31-2012, 11:36 AM
ml350 2003
THANKS!
Maj. Dundee,
Thanks for the information. The top attach bolts look a bit challenging...but I will give it ago as soon as the Bilsteins arrive.
Old 08-12-2015, 09:40 PM
Felipe Alves's Avatar
2003 Mercedes Benz ML350
2003 ML350
I was curious. I know this is an old post. I am looking to purchase bilstein rear shock and strut assemblys. Did you find them easy to install? Was the brand worth the money or better just to buy Mercedes Original? I have to do my fronts as well. Seems like online its only Struts. Not sure if you have had to do those yet or the control arms / ball joints. Just finding the everything I have been viewing on videos / reading has been really difficult and time consuming to change. Appreciate the feedback. Thank you.
Old 08-13-2015, 03:16 PM
art_arev's Avatar
2003 ML55,2007 ML63
They all are the same, when it comes to installation. The rear ones you are better of to buy the complete strut assembly. If you buy separate shocks & the springs, then you will have to fit the spring onto the shock. This is very difficult & dangerous venture. Or you will have to find a shock shop were they can fit the spring onto the shock.
Brand wise......It is matter of choice. I have SACHS installed. They are great.
Bilstein is a very good brand. Original Mercedes is going to be SACHS. If you want original, you are better of buying SACHS (in SACHS packaging). Don't buy from the dealer. You will get SACHS in MB packaging for twice the price.........
Quick Reply: ML350 2003 rear shocks replace.
