Daytime running light DIY
ML320
I have a 2001 ML320 and want to add two pieces of daytime running light (DRL) at the lower grill. I was told that I should get power from Terminal 15 of fuse box with 7.5A fuse for each power supply. However, I don't know where to ground it. After looking for some reference, I notice that there are grounding point right behind each headlight. Can I use those grounding points to ground my DRLs?
