DIY Expansion Valve & Dryer Replacement [Follow Along]
98 C230
Hi Guys,
I want to log the events of my attempt to do a complete DIY Expansion Valve & Drier replacement.
There was a great thread a few years ago that had various attempts and different people chiming in, but I wanted to start with a clean slate. Here's the other thread for reference - http://www.benzworld.org/forums/w163...0-ml430-8.html
For starters, I have a 2002 ML500 sport package with a whopping 291k miles. 99% of them are highway miles, so I like to think she has about 200k on her . Always maintained, engine runs incredibly strong, transmission doesn't skip a beat. Have done some major repairs, but I think she's on her last leg, and don't want to put any more money in it. Therefore, I'm doing this as cheaply as possible! (Fingers crossed!)
My mechanic is quoting me $1100 for the expansion valve and drier replacement after finding a leak at the valve (and most likely the o-rings). So here's my plan. If anyone believes I may be missing something, PLEASE chime in as I am good with cars, but not GREAT.
Parts I am purchasing (all from PartsGeek.com and of course for my car)
1) O-Rings
2) Drier
3) Denso Expansion Valve
4) Vacuum Pump w/ manifold gauges (friend has one I can borrow)
5) Freon
From there, the plan is simple,
1) Evac system
2) Replace Expansion Valve, O-Rings, and Drier (T-30 Torx) courtesy of great schematics from other thread.
3) Recharge system with freon
4) Cross fingers and toes.
I'm planning on doing this in 3 weeks, and will be reading everything I can find on the subject matter, and watching every YouTube video I can find.
I'll keep this thread updated, but wanted to ask, is there any glaring thing I might be missing?
Thanks so much, and be sure to check back!
1) O-Rings
2) Drier
5) Freon
1) Evac system
Save yourself a lot of money. When there is a leak at the Expansion Valve, it is always due to the O-rings. The Exp. Valve is a block of aluminum and does not leak. You should only replace it if the valve itself is not operating, and this is not your case.
Replacing the drier is also needless. The only reason for replacing it is when the system is left open for a prolonged period of time. That is when the internal desiccant bag starts absorbing moisture.
After separating the Exp. Valve, replace the two O-rings and reattach. This should take no more than 5 mins. Then evac. and your problems are over.
98 C230
