Refrigerant Pressure for a 2002 ML500? Help please!
98 C230
Anyone have this info handy? I've read that the system holds 750g? Can anyone else verify? The sticker is gone on my truck. Thanks
98 C230
I would have advised you to have it done at a AirCon shop by professionals. They will hook your car up to a machine. Its not just the gas but also the compressor oil & leaks they check.
But if you decided to do it on your own , I would advice NOT to overfill. Better if you will be a bit short then more.
98 C230
I'm using a can that has the oil in it. See my other thread about everything else I'm doing to the AC system prior to me charging it.
https://mbworld.org/forums/m-class-w...low-along.html
