No Start, No Codes, Engine Cranks
I have a 2006 ML350 that does not like hot weather. 105k miles. On hot days it will start and die or simply not start. Leave it overnight with temps in the 50's and it will promptly start in the morning. I have changed the crank and cam position sensors. Thinking that fuel pump should be next.
This ML runs great or does not run.
Check engine light is not on and OBD is not throwing any codes.
Any suggestions or thoughts will be appreciated.
You are in the wrong forum. This is W163 (1998 - 2005 ) forum. I have to be on W164 forum.
Otherwise it sounds like a CKP sensor ( Crankshaft positioning sensor).
Scan the car with a pro level scanner.
Last option is relocate to a colder climate area.........
