Need help removing the BrakeBooster
Trying to replace the Brake Booster on my 2001 ML320; there doesn't seems to be enough room to get the master cylinder out without removing/moving the big electrical wiring box; otherwise, the back doesn't clear past the booster bolts. Any help would be greatly appreciated.
Anyone reading this, need to remove brake lines and then the MC followed by the bracket that has the Cruise Control unit attached to the Firewall. It is a press fit so you fill have to push the plastic tab in from the right side.
