no light for outside temp ml320
Old 02-27-2015, 07:41 AM
spudkth's Avatar
2001 ml 320
What/how is the fix for 2001 ML320 that has no light for the outside temperature display??
Old 02-28-2015, 07:20 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did you consider that a bulb is out?
Remove the Instrument Cluster.
https://mbworld.org/forums/m-class-w...ml#post6233014
File Type: pdf
Old 03-01-2015, 06:28 AM
spudkth's Avatar
2001 ml 320
bulb for outside temp
Thanks. Was not sure if they used "bulbs" or had some other method of illumination. Is removing the instrument cluster anything one can tackle and/or does it require special tools?
Old 03-01-2015, 06:48 AM
art_arev's Avatar
2003 ML55,2007 ML63
Read the PDF in this thread.
https://mbworld.org/forums/m-class-w...ml#post6313809
Old 03-04-2015, 10:04 PM
DrX
DrX's Avatar
2002 ML320, 2003 A160
Read the tips for this how-to video.
Quick Reply: no light for outside temp ml320
