ML500 brake size?
ML500 brake size?
Does the ML500 share the same brakes with any other w163?
Would brakes from a ml320 or ml430 fit?
Would ml55 brakes be an upgrade?
00 C200 & 00 C55 & 06 SLK55
ML500 brakes;
Front Rotor is:- (303mm dia.) & (26 thick.)
Rear Rotor is:- (285mm) & (15mm thick.)
*in some ML500 models, all brakes are the same with ML55, which is:-
Front Rotor is:- (345mm dia.) & (32 thick.)
Rear Rotor is:- (330mm) & (14mm thick.)
*it depend of your ML500 brakes spec...
ZAYED,,
ZAYED,,
Early 500, like mine takes the pre facelift 2000 & 2001 55 & 430 pads. It is the year, it has nothing to do with sport package.
Its tricky, your best bet is to compare samples.
