Radio alarm help
Ml320
Radio alarm help
Hi, i installed aftermarket cd player for my 98 ml320 with harness from amazon, now no arlarm or remote lock, how do i get that back?
Thanks for ampny help, i tried google
Remove your CD player & unplug the new harness & see if the remote & alarm are back.
Doesn't matter what people sell. You have to figure out if removing the harness fixes your problem. If it does fix your problem then the issue is with the new harness.
Ml320
Ok i will try, if that works where can i get a good harness
2002 ML320, 2003 A160
You know, people say they check all their fuses, but I don't believe them: http://www.benzworld.org/forums/w163...l#post11393090
It's nothing personal.
Ml320
Popped the hood checked every fuse and ALL are good, also noticed theres a cd changer, so that s what the other part of the harness to factory radio went to....still no alarm
The alarm and remote locking are both functions of the AAM.
Please tell us which of the following features are working or not working;
- Central locking button on the center console (window switch group)
- A/C fan
- Windows auto up/down
- Interior lights auto on/off (with door opening/closing)
- Intermittent wipers
Ml320
- A/C fan
And the fob hasn't worked since? Are the batteries correctly oriented? Are the contacts clean and not corroded or fouled with battery fluid? Does the side contact make good contact with the top battery? What is the build date of your ML (mm/yy)? For early MY1998, the remote fob synch procedure is different.
