2002 Mercedes Benz ML320. Replacement AC compressor problem
Old 07-04-2015, 12:40 AM
ngjonathan91's Avatar
2002 Mercedes ML320
Hey!
Have a 2002 MB Ml320, had AC compressor replaced but replacement has different clutch with external wire.
Original has internal clutch, which engages from inside compressor with a 2 wire switch from rear. Is this an AC voltage signal or can the replacement compressor still work?? And how?
Purchased Denso A/C Compressor Part Number: 6417-07190535 from Partsgeek.com
Old 07-05-2015, 03:38 PM
art_arev's Avatar
2003 ML55,2007 ML63
If you have a 2002 model, it means you bought a pre face lift(older model) compressor. It wont work on your car.
Quick Reply: 2002 Mercedes Benz ML320. Replacement AC compressor problem
