please help me,i'm stuck
mercedes benz 2003 ml500
hi everyone,i'm new heres
light on BAS/ETS/ABS/CHECK ENGINE
i need help with my 2003 ml500.i was parked then i try moving shifter but will not move,i played with the lever then move from park to drive,then will not go over 40 mph..
my van is in limp mode,i have a obd2 scanner and i get code p0705(transmission range sensor),so i went an buy conductor plate from mercedes benz.i i replace it with new plate.fill with 6 liters of mercedes benz transmission fluid.start van let idle for 30 min ,moving leaver from p-r-n-d is ok but from d-n is ok but from d-r-p,it have a hard shift..
then i drive car to see if it goes over 40mph but no luck..
check engine light is STILL ON.
i check with my obd2 scanner on code p0753 is on (shift electricial A solenoid ).. so my question is how do i go about to resolve this issue?
i will like to buy a scanner to read transmission codes,removing it,and reslove this limp mode..
can anyone help me,i;m stuck..
thank alot in advance.
have a bless day
have a bless day
Foxwell http://www.foxwelltech.com/product/item-14.html Or Autel
work good with MB cars. Assuming that you have replaced the conductor plate correctly, you must clear the codes in ETC & other modules. Generally, make it a habit to clear codes after any TRANNY repairs.
